984 Ford Ranger Race Truck 1450 sportsman
brandon12911
245
Yucaipa, CA
Race Truck / Pre-runner for sale
1984 Ford Ranger / 1973 Ford Pickup (Smog exempt street legal)
Full Cage front to rear. Has tubular core support for engine removal.
Motor: Ford 4.0L engine with custom ground cam, block was decked with heads and intake ported to match.
Transmission: Ford C4 tans with manual valve body, Kevlar bands and drums machined to accept 6 clutches instead of standard 4, hardened output shaft with bolt on flange for driveshaft, input shaft and drums also hardened with modified factory cross member, ART CARR gate style shifter with linkage.
Rear End: fully gusseted Ford 9" with Strange aluminum center section, 5:13 gears and full locked spool by Strange, axles are 35 spline Currie gun drilled custom length. Has explorer rear disc brakes
Custom Aluminum Dash with auto meter gauges for Tach, oil temp, oil pressure, water temp, trans temp, volts.
Fuel: 34 gallon fuel cell (needs foam), high pressure fuel pump by MSD.
Front Suspension: McNeil equal length I-beams with swing set steering (Giant Swingers), 14" king 2.5" coil over shocks w/ dual stage springs, mounts for additional bypass shock (16").
Rear Suspension: Deaver Race Series rear springs with 16" King 2.5" triple bypass shocks
Wheels: Truck has F-150 wheels wrapped in BFG Baja terrains, comes with three extra rims / tires. 35x12.5.
Possible Trades: Toyota land cruiser 4x4, steel buildings & cement work
Asking $9,900
Call or text if interested; Brandon (909) 754-2891
