ABS REMOVAL
andrewzermeno
Mar 4, 2017
45
5
Madera,CA
Hello,
Have a buddy who installed a giant motorsports engine cage and it interfered with the ABS. So he has since removed it and trying to figure a way to run a proportioning valve or something to get it to work without the ABS.
Currently has 3 lines just hanging that were connected to the ABS.
ANY HELP WOULD BE APPRECIATED!!
Truck is a Ford Ranger 1996 EXT cab
Front disk brakes
Rear drums
camburg 4.5 over beams
rear deaver pack
kings on all 4 corners
andrewzermeno
Mar 4, 2017
45
5
Madera,CA
Two of those lines are probably for the front. The other is for the rear. Run one line to the master for the rear. The fronts get teed together and will be run to the master. Plumbing the prop valve in will depend upon the type you use.
AWESOME! Thank you for the help! Not one mechanic wanted to touch it here in town lol
I'll post pictures once it's done!
