themoneypit
Jul 30, 2018
563
830
Missouri
Added the last two horizontal tubes at the base of the B pillar, and the cab cage is pretty much complete.
225017
After that, I started the sheet metal work. Holes all patched with 16 gauge plate.
225018
225019
Just have to patch the slit in the trans tunnel and the area around the B pillar and the floor will be solid once again.
bassist21685
Active member
Mar 27, 2009
1,939
ventura
Killer build! I love how low profile the cage is, and then you take it all in and see the mezzanine arms... and shit! Well done.
themoneypit
Jul 30, 2018
563
830
Missouri
Threw together some dimpled B-pillar to cab plates, and then notched some door bars. I'll likely add another bar to make a proper X later, but I'll need the dash in place first to check clearances.
225088
225089
After replacing the melted wiper linkage bushings, I welded the cowl panel back in place as well. Fingers crossed I don't have any weird windshield install issues later.
225090
