We have
I found the cheapest Bills were from AJusa online store. I paid $90 each.
My friends own auto shops so I used their professional spring compressor. Probably worth the $50
I ran 285's for about 10yrs with no spacer on the stock wheels. Only slight rub on full turns. I added a 1.25 recently because it started rubbing more for some reason. I think the BFG newer design may be a little wider???
Rub all depends on which wheels you have. Friends with same year truck and different set of factory rims could not run without a spacer.
Ok cool. That actually helps give me an idea. So we have a rapidly developing situation here. I decided WhyTF am I going to buy 2 Billys to essentially lift the same spring and marginally better shock and not get virtually any benefit for that $225+spring compression cost and instead go with a 2" spacer lift which is going to be easier to install, less hassle, and it was $42. That should facilitate the 32.8 (metric 33) for the time being and do exactly what the Billy set up will provide.
Now, with reading what you wrote we'll see if I still need the 1.25" spacer with these LIMITED 17" alloys. I'd prefer no spacer but I also prefer no rubbing and again, this would be for the time being. Hopefully to get rid of the spacer we would buy new wheels with the built in backspacing/offset. Not a pro with that still learning. I think we would need a 0 offset or negative if I'm understanding that correctly. I believe the stock wheel is a 14mm offset. Wheels, UCA and KINGS BRO would take care of the spacers and as TURBOYOTA would say, "throw those spacers in the garbage".
So right now, on the way, I have:
- 285/70/17 Toyo Open Country AT3
- CHINA (DT voice) 1.25" hubcentric (with raised inner lip) billet aluminum wheel spacers (4)
- CHINA 1.5" coilover spacer (level spacer)
I plan on letting the rear SELF CLEARANCE, anyone object to that idea? I considered raising the rear in the same manner with a spring spacer for 1" total lift but I don't even want to go down this route at all. Waste of money. I only need the absolute minimum to get by for a couple of months until KINGS BRO!!!!!!
The other reason the situation has been fluid and rapidly developing this morning is because we only have 10 days until MEXICO brahhhh and I don't want to order something incorrectly and jeopardize not being able to drive this PIG OINK OINKKK!!!! This rig definitely ain't KOSHER baby!
