Smash back or cut the corner of that pinch weld, tire fit on the seq/tundra are suuuuper picky about alignment.
Running aftermarket ucas will change the upper control arm ball join position. You can chop the pinch weld back quite a bit, I cut it back flush with the flat section at the bottom where the rubber bung/drain is in the picture labled "got eeeeem". Then cut some relief cuts in the wheel well itself and flatten that back. I was kind of conservative on how much I chopped mine but I didn't want to push the wheelwell back into the cab much more than I did. If you knock it back much more, it changes the position/angle of the "dead pedal" which feels weird once you are used to the fit.
If you cut and weld, make sure you pull the foam out of the corner area or you will set your shit on fire.
It is really hard to get halfway decent pics of this since its dirty black herculiner inside a wheel well. My tires are 295/75/16 on 16x8s with 4.5" bs. They rub frame at full lock but nowhere on the fenders or cab. Height wise, I probably could have fit a 315/75/16 but with 4.56 gears it would have been more of a dog and would have required spacers to keep it off the frame.
