Hubs are on and everything is in except
One c clip on the drivers side
One lower ball joint bolt also on the drivers side
Two axle retainers on the front axles.
I also am missing the hardware to bolt in the front driveshaft. Then its just a matter of filling the front diff up and this tundra is officially 4wd.
Prior to installing the new wheel bearings, seals, and hubs I tossed the spindles into the blast cabinet to try and clean up my shitty welding (it didn't work). At least the seymore (butts) stainless paint stuck well.
I cleaned up the inside races of the spindles and installed new oe bearings and seals, then pressed in the new (aftermarket) manual hubs flanges.
The drivers side turned out great and went in fine, the passengers side did not. I had to replace on of the roller bearings in the passengers side hub because it was way too tight on the axle. Even after swapping it out, its still tighter than I would like. I may see if I can get a new oe hub to replace this one.
New total chaos uniball adapters, bolts, and misalignment spacers completed the spindle swap and bolted on to the camburg arms I had on the truck.
Spindles (Don't zoom in)
Wheelwell Shot
Fender Shot
Money Shot
