Horunner
If your tires are worn funny I’d suggest rotating them to the rears then trying again. My km2s started wearing funny and causing a weird vibration. Rotated them and they rounded out. No idea what caused it but it happened.
I will probably do that anyways but the rears aren't much better. I had really bad lower control arm bushings when I first got the tires put on, then once I fixed it, the shop that did the alignmnet put way too much toe on it. Realistically, it needs 5 new tires but I don't want to do that yet.If your tires are worn funny I’d suggest rotating them to the rears then trying again. My km2s started wearing funny and causing a weird vibration. Rotated them and they rounded out. No idea what caused it but it happened.
Depends on the tire and how long it was sitting. Probably not unless they’re like race compound tires like Baja TAs or something. Did you knock weights off the wheels when you were doing work on the suspension and cvs and stuff? If your cvs aren’t spinning and driveshaft hasn’t been smacked or is loose I’d guess it is something to do with balancing/uneven wear. Does your steering wheel shake or is it just felt in your ass or feet?I will probably do that anyways but the rears aren't much better. I had really bad lower control arm bushings when I first got the tires put on, then once I fixed it, the shop that did the alignmnet put way too much toe on it. Realistically, it needs 5 new tires but I don't want to do that yet.
I should mention, the tires are on the same spot as before so really the only thing that could have changed was the allignment.
Could the tires have gotten flat spots from not being driven? I have not put many miles on it for a month or so.
That is strange it’s not in the wheel. Def check the u joints.They are goodyear duratracs, not race tires at all.
All weights are accounted for.
It vibrates the seat/truck, thats the weird part. I have driven unbalanced front tires and it shakes the crap out of your wrists. This feels like a bad u joint. May be time to yank the rear shaft out and swap all the joints for new ones.
It’s like anti rust coating when the grease goes everywhere.Rebuilt the cv joint and flug grease allllllllll over the bottom of the truck but at least its super smooth now. The front shaft also needs to be rebuilt because at 50+ in 4wd it starts to feel like sitting on a magic wand.
The front shaft looks like standard 1310 u joint with standard squiggly clips though so there is that.
