Beaumont Built "Mai-Tai-Yota"
Motiracer38
Super Senior Member
Feb 14, 2006
3,425
72
Santa Clarita
I've been cranking away on the back half. Got the tube work done to the bumper, decided on dual spares laid side by side. Swapped the fuel cell for a jeepspeed to keep it under the bed rails. I even finished up the sway bar mount, arms, and links. It uses a 1.25x 42" bar and 22" arms mounted to the trailing arms to maximize rate at ride height. Brake rotor adapters are even in work.
Sent from my moto z3 using Tapatalk
806
By maximize rate at ride height... you mean link and tie rod are at 90* at ride height?
The Camburg set up I have is a 40" bar out of 300M I think... and also turned down to 1.25". I have 24" arms that I can adjust from 24ish-28ish. BroDaddy has 28" arms with same bar.
Sounds like you are in same general ballpark. You will LOVE it.
Motiracer38
Super Senior Member
Feb 14, 2006
3,425
72
Santa Clarita
Not so much 90, but the angles are equal between the sway arm to rod and rod to link centers. I think the sway arms will run uphill at ride height a bit to match the lower link angle. Hoping it's close enough, I've never run one off road
