Blanco Taco Build
FlapJack935
Oh i Member
Jun 26, 2017
152
98
New Mexico
There it is. Perfect looks badass
Thanks! Interested to see where my rear trunk ends up and see if the 2 spares can get squeezed into the bedsides. Quick PS for an idea of tube layout. still undecided if i need the purple diagonal tubes where the cell will be behind the cab and then doing shock towers that come off the down tubes from cab so maybe not needing the lime green tubes either. Not sure yet on those guys
223599
10,102
1,270
I had the down tubes and purple but not the ones to middle below the back window since my fuel cell was in that spot and removed out the top. And no green outer tubes. My shock mounts tied into the tube into cab below back window and was bent to the c pillar as well.
Reactions: FlapJack935
1,696
nice progress. I dig the alternating flared hole to tube hole!
But, hope you put a big drain hole at the bottom of those frame rails...
FlapJack935
Oh i Member
Jun 26, 2017
152
98
New Mexico
yea were gonna do a drain at the bottom. if it becomes a problem we'll cap the dimples and can be a little detail instead of being open. Was an idea we decided instead of just dimples or just tubes so we alternated.
FlapJack935
Oh i Member
Jun 26, 2017
152
98
New Mexico
Rear cut out. Gonna cut the floor out also to tube and plate the rear half of the cab also in the future. But firewall cut out, frame rails on, back section on the table mocked up. Also their 1450 truck in the shop getting work done also. Getting some momentum!
I’ll get more pics here soon
223646
