Bronco engine cage clearance
Jsandoval27
Sep 24, 2021
2
Orange county
I’m starting a prerunner build on my 94 bronco, and I’m wondering what to take out/ move around in the engine bay in order to make clearance the the engine cage and shocks. Any input would be appreciated thanks.
10,917
2,141
WEll step one is the remove the entire motor/trans/t-case and then remove all heater/ac stuff and start with an LS swap. Then you will have lots of room to build around. So take out/move the entire ford motor/trans/t-case along with the stock rear axle. Then you will have lots of room to Kook around under the hood
Reactions: mikey09120
6,791
9,540
What size tires?
Keeping heater box?
Fab skills?
Ability to remount fuse box and computer?
Keeping smog faggotry?
What motor?
