Long story short, I picked up this Bronco back in February, the same time my son was born. So progress has been slow, specially in the beginning so bear with me, but starting to get somewhere with it. The first couple posts won't exactly be in chronological order as I bounced around from one task to another depending on how much time I had to work on it. Im organizing by task/project till I get to present day, then I will probably post as things get done. On with the show!
Here are the pics from the ad:
1994 Ford Bronco 5.8L with 127xxx miles. Fiberglass all around with stock beams and 4-6" lift with extended radius arms and pro comp shocks. 4.56 gears front and back. Twisted Stitch seats, method double standards and 35" grabbers. Tube bumper with valence and of course, a 50" light bar on the roof. Also had some train horns and compressor, kickass autozons cone filters on factory intake tubes, and a sweet Plasti-Dip paint job. Unfortunately it wasn't as clean (to be expected) when I brought it home and started tearing into it, but it was a trade deal and still worth it. And here she is the morning after I brought her home.
I kept my method beadlocks in the trade and threw those on before loading it on the trailer. At this point i knew the interior needed a deep cleaning, and the seats needed to be re-mounted in a better position. and both windows will roll down but not up. Which is the first thing I fixed, just needed to replace the bushings in the motor (no pics). At that time I also replaced the window weatherstripping. And since i had a newborn I continued with quick and easy (and cheap) projects, as well as just going through figuring out the plan of attack.
New LED headlight bulbs (on the left, halogen on the right) I also did LED's for all the bulbs I could
Then I was getting tired of the Wal-Mart telescoping hood prop, so I picked up some gas props and mounts
Then I started redoing the seat mount to have a better seat position and strength so they don't wiggle around, as well as adding a tilt mount to the passenger side. I decided I should probably remove the carpet and clean it at this time. I also swapped out the Twisted Stitch seats for my Beard TS1's Ive been holding on to.
While doing the seats, I also started on the center console. I decided I wanted to go with an OEM look to the interior, so I picked up an Expedition console (05-06 i think) and made a mount for a double din radio I had laying around. Will have cameras installed in front and rear. Under the console will be a 4ch amp and an 8" sub. the sub will take away most of the storage from the console, but I wouldn't want a lot in there anyway. The amp will power the front speakers and the sub, while the rear speakers are powered by the radio. I will then put my Kenwood TK-730 in the factory radio slot and my Rugged Intercom in the cubby by the steering wheel along with a rocker switch. I drew up the intercom mount and had a buddy cut it out for me. I also picked up a SwitchPros knock-off that fits perfectly next to the 4x4 switches. Along the way I noticed that the horn wasn't functioning, narrowed it down to a bad clock spring. Not wanting to spend the ridiculous amount of money for a new one, and getting tired of getting in and out around the steering wheel, I opted for a quick release and a suede steering wheel from MPI. I also have been cleaning and replacing/fixing broken interior pieces like the dash pad, ac vents, trim pieces, etc. As well as removing the amazing wiring the PO left behind. So much better.
And a little carbon fiber wrap to help
Almost finished with the cockpit. Still need to finish wiring and cleaning it up, but you get the idea. Oh that reminds me, I still need to install my Desolate dash brace. During all this work I was working out what I wanted to do for suspension. Originally, I wanted to do stock width, but found a great deal on 4.5 over beams and I already had the fiberglass. So i picked up the beams/radius arms along with extended axles, extended tie rod adjusters, a trussed 9", deavers, solo engine cage, factory beam brackets (since mine were missing due to the lift) and misc pieces from a guy parting out a bronco. Then I went on a part collecting spree... Picked up Solo shackles and hanger drop and Desolate radius arm brackets. Then came the shocks, SAW 2.5 x 14 coilovers, King 2.5 x 12 Bypasses and old school SAW 4.0 Internal Bypass Coilovers. Plan is to run the 2.5's up front and run the 4.0's in the rear as just bypasses. Traded the Seats that came in the bronco for a Solo underbed shock mount and a sweet keychain. My wife took my son to the river since she had a week off and since I wasn't heading out till the weekend, I pulled the bronco in to install the new suspension. Nothing went as planned... Took the leafs to Deaver and found out they were not only Nationals, but once torn apart, they suggested not to run them at all, so a set of new Q80's it is. Then I found out the PO welded the beam brackets to the frame.... After I tore it apart, I noticed the 4.56 gears were actually 3.53's... The shock mounts on the beams were not ideal either. So i drove the bronco into the garage Wednesday after work, and back out after work on Friday. No front axles or third member, no front brakes, and towed out like a mother (one adjuster was twice as long as it needed to be...) , but under its own power.
