Bronco Sin Nombre!
Bertismyname
Oct 1, 2018
879
295
Caster need to be measured at ride height. 10 to 15 degrees will help it track straight and get the wheels to return to center on their own. I beam trucks need a little more caster because they lose caster at drop. If you are truly at 14 degrees you doing well.
Reactions: yltaco05
Bertismyname
Oct 1, 2018
879
295
Two to 3 degrees negative camber at ride height and about a quarter inch of toe will get you tracking straight. Make sure your rear axle and front are square to each other and square to the chassis. Do your best to minimize toe change and bump steer through the travel. Not always easy with I beams or ttb. Take your time. Measure and take notes. I would also lock out the beams with temporary support welded to them so you can set your angles at ride height.
1,527
342
Sweet I’m definitely in the ball park. Close enough to measure for rad arm length, tack those together so I have one less thing to move on me. Fine tune from there.
1,527
342
Alrighty, here’s a quick tease.
At ride height, 12 degrees of caster, 14 at bump, didn’t check droop. 106.75 wheelbase.
9,462
538
Phoenix, AZ
Also I would check caster with a longer rod through both the upper and lower ball joint hole. The way you have it now it looks like you actually have a few degrees more caster.
Also check pinion angle a bit. I haven't setup a ttb setup with more than 9deg since driveline angle would be way off.
Reactions: yltaco05
1,527
342
The beams are nearly flat at ride height but I’ll check. The radius arm mounts on the beams have 7 degrees built into them
