Bypass piston.
9,867
643
At least an inch of the short tube. Usually you would want even spacing. Say you have 9" of uptravel from ride height. The first tube would be 3" above the piston and the second would be 6" up. Unless you're buying custom shocks, you're stuck with the standard setup.
Reactions: DEZRT GM
382
^^ I always wondered if you would want the bump zone to be less spacing because it's so aggressive?
Meaning, if I could actually make custom shocks... maybe in the scenario above.... I would only want the last 2" as bump. (so, it would be at 3.5" and 7")
I mean with those numbers it doesn't make much difference. But, if you had like 13-15" of up travel it would. (which is what I think most of us with notched frames have in the rear).
With 15"... the even spacing method would net you a 5" bump zone! That seems excessive.
oorracing
Jan 15, 2006
10,548
60
Long Beach Ca
The problem isn’t the spacing on the bypass tubes for longer shocks, the problem is the lack of tubes. Add some compression and rebound trim tubes to your shocks and youll be amazed at the additional comfort you gain. Take a look at the tube layouts on the big shocks and you’ll see some with a small 1” bump zone. However they have 4-6 tubes that shrink in lengths and diameters as they get closer to the bump zone which effectively reduces flow and makes a much smoother damping curve. I’d rather have 5-6 zones that transition smoothly vs 3 zones with harsh transitions
Reactions: FasterNU
