Bypass valving opinions
84prerunner
2:AM Fabrication
Feb 7, 2008
21,505
73
Covina CA
Revalving the rear 3.5" bypasses on my linked yota. Biggest issue currently is the bump zone is too soft, in the bigger g out type holes it slams the bump stops. Rebound is also borderline too slow, even with the tubes wide open, I believe this may be contributing to it being slightly harsh in the steeper whoop rythem sections. Current valving Comp: biggest 2 are .012s, then 6 .010s plus a rate plate. Rebound: all .008s (6)2 .086" free bleedsWithout making it harsher in the choppy stuff, what would you do?
9,867
643
Go .020's on comp. Plug bleed holes. Run a bleed poppet in the long comp tube. Maybe one in the rebound tube to if you can't control the chatter. Normally I would say chatter is in the CO, but those are some pretty big shocks for that thing.
84prerunner
2:AM Fabrication
Feb 7, 2008
21,505
73
Covina CA
You don't think going from 12-10 combo to 20s is going to make it harsh even when not in the bumpzone? The coilover is a 2.0 with .008s comp and popoff rebound.
9,867
643
No, your bypass tube should flow enough to make piston valving irrelevant under low speed conditions which is where your chatter problems are.
84prerunner
2:AM Fabrication
Feb 7, 2008
21,505
73
Covina CA
what are you referring to as a "popoff rebound" stack in the 2" coil over?
exactly what partybarge said....its a machined plate with a spring that holds it shut to plug the holes during compression, then it blows open on rebound providing basically 0 damping effect
