Camburg long travel shock mounts
11,598
2,750
Tilt it in a little more if you can. It's 90* from the pivots, not the top of the arm. If you drew a line between the pivot and the shock bolt, you want to be 90* to that.
Reactions: mikey09120
DA Ranger
Chasing Dreams Offroad
Sep 11, 2005
285
9
Corona
Thank you so much. Also for the bump should it strike the bump plate at a certain angle?
11,598
2,750
Bump can go a little less than 90* to the bump pad. Mock it up and see what makes it slide on the pad the least. Usually about 90* to the pivot line at half stroke.
