Circlip position in Uniball for UCA
96f-u250
825
96
VenTurA 805!
I am about to start making some upper control arms for a 05 F150 4x4. The upper arm is going to be using a 1” uniball bolted vertically (bolt vertical) to the upright. The arms will not be interchangeable. So which side should the circlip be on the Uniball? Top or bottom? Its hard to imagine where the force will be going and if this matters. I looked at Camburgs and True Travel Dynamics and it looks like the circlip is on the bottom, or upright side but its hard to tell. Thank you.
Klever
610
9
Snap ring goes on bottom if the uniball is mounted horizontal. If vertical I would put the snap ring facing the rear of the truck.
96f-u250
825
96
VenTurA 805!
Right on, I appreciate the reply. So, bolt vertical means Uniballs horizontal. That’s what it looked like others were doing. Any reasoning behind the positioning?
Klever
610
9
No problemo man. The uniball is technically made to run horizontally (strength in surface area). Many people run them vertically with short arms to get the misalignment for travel (unlimited, this would limit steering angle because of misalignment. Both will work fine.
Drayke
Always Baja Bound
Jan 29, 2007
877
69
Torrance
Made to run horizontally? No.... spherical bearings ("uniballs") are waaay stronger loaded radially than axially. Suspension applications where the bolt is horizontal are stronger with respect to the bearing, but there's plenty of reasons to not do it that way on a truck.
Yes, they work both directions, and yes you should put the retaining ring on the upright-side in my opinion as well.
reference: check out any spherical bearing distributor's catalog pages. They all quote the radial load allowable and often won't even bother posting the axial rating.
Here's FK's page as an example: https://www.fkrodends.com/products/spherical-bearings/commercial-series/com/
9,855
635
Axial load rating is only 10% of the radial loading. Also the suspension cycles much more than the steering. Every time the misalignment spacer cycles into the race it will take crap with it increasing wear.
To sum it up, horizontal mount is dumb for the lower. The upper where it only see's braking forces it's a toss up. It will still wear faster though.
96f-u250
825
96
VenTurA 805!
Thanks for the help and replies. This is just a cheap fix for a stock coilover spacer lift to get better droop angle and get rid of the ball joints.
