Cleaning out the shed again
zachwabbit
Oct 18, 2017
189
45
Jamul
Local pickup in SD or may ship some items on your dime.
James Duff 4x4 Ranger/Expo/B2 extended radius arm crossmember
$40
Pair of Autofab 4” lift stock length 2wd Ranger radius arms with bushings $200
x2 stock Ranger radius arm mounts/crossmember
$35/each
Stock A4LD trans mount crossmember
$15
‘89-92 Ranger stock steel hood and latch, good shape just needs paint, only surface rust
$40
Pair of stock 4x4 B2 coil buckets, small piece cut off one side at the brake line clip hole
$15
Pair of Bilstein 5100 front shocks
$75
4” drop pitman arm (FD-400)
$60
Valley hitch for OBS full-size Ford’s
$50
2006 Jeep Commander 4x4 front driveshaft
$40
Pair of brand new Alpena clamp-on brackets for round tube
$30
x3 Optima battery height adapters
with assorted group adapters and spare accessory terminal covers (new and used)
$Make Offer$
