Deaver u-182 setup
6,015
337
when i ran em i used the mazulla shackle and hanger. when i tried to use a longer shackle they got a shit ton of separation in the leafs early in the droop stages. i believe mz hangers actually are moved back and UP to accommodate for the short shackle to give you a decent ride height cuz these leafs sit pretty tall otherwise
Reactions: NODNARB
NODNARB
28,373
389
Rancho Cucamonga
www.btf-fabrication.com
Good to hear, so we can probably use one of our 4.5” shackles and make a hanger. Moving them up a little makes sense because we got it mocked up and at full bump there’s a good bit of negative arch right now.
6,015
337
yah the hanger moved up took some travel away on the droop side but they worked pretty decent. not much better over the f87s imo
9,272
305
Phoenix, AZ
Jeff at Deaver told me to just run the stock hangers and shackles with the U-182 and it'll work fine. Moving stuff around will not net you anything more he said.
