Dent side Build thread recommendations
CGILES01
Feb 4, 2009
55
5
I’m getting ready to start collecting ideas and parts for a 79 F-150 super cab build does any one have some good recommendations for dent side builds?
Bertismyname
Oct 1, 2018
934
322
My reasoning for the frame swap is this . The bump and dent side frames have a ton of flex. Welding cages to them is tough to do and not have the truck tear itself apart. Rear steer is hard to package with a swinger. Suspension options are limited to one or two manufacturers. An 80s or early 90s frame has more options for suspension and powertrain. I've fought steering issues with my bump side and I'm still not too happy with it. Bump steer is tough to eliminate with the rear steer.
CGILES01
Feb 4, 2009
55
5
I’m building it as a dedicated dune toy. I run and program Cnc machines so plan to build everything. The truck is getting back halfed. I plan to run custom king pin beams up front. Will most likely run front steer not keep the rear steer. The frame will get boxed front to rear and power plant is planned to be a coyote motor. I’m starting with just a cab and frame and building the rest. I have been building jeeps and rock crawlers for a few years. This is also not my first pre runner.
CGILES01
Feb 4, 2009
55
5
That thought has crossed my mind. Keeping the stock frame does give me a starting point but we will see what way I go when I start the build. I’m just In The info gathering and parts collecting stage right now
Reactions: Brandon_Charley
