Different Link Configurations, Pros & Cons?
RanchRanger
Mar 24, 2017
10
1
As the title says, what are the advantages/disadvantages of the different types of “desert style” link setups with the shocks mounted on the lowers. Such as a triangulated 4 link or 3 link. Possibly something like the giant DD link with a pan hard bar, or similar setup with a single upper instead of the small gas shocks to fight axle wrap. I have a ‘93 ranger that I’m planning to back half and link this winter. I’ve been debating which route to take. I live in rural Montana so staying street legal is not very difficult, but I do worry about onroad handling on my way to and from wheeling. Is one configuration more road friendly than another? I can see how different types would be easier to fabricate and make antisquat, alignment, pinion angle adjustments etc. but what about the ride quality? Thanks
5,979
307
I absolutely LOVE my SI Motorsports 4 link set up. i do a lot of street driving and it has good street characteristics. ive never seen a giant dd link kit in action but it is cool that it allows you to keep the stock gas tank and all that stuff.
Reactions: ljubera0250
691
143
something other than a triangulated 3 or 4 link means you are trying to build around something factory you dont want to move. IE, gas tank, exhaust, keep shocks out of body, etc. If you are back halfing it, the best bet would be a triangulated 3 or 4 link. the difference between a 3 or 4 link is the upper mounts. you will either bring both upper links together and use 1 heim or uniball as the pivot point at the axle or you will keep both upper links separate from each other and use two heims at the axle end. This setup would be the best handling IF designed correctly.
9,855
635
The lower arm tabs on the axle were sticking straight forward on the ones I have seen. Puts a shit load of pressure on the uppers. It also fucks with the anti-squat numbers. Plus having the mounts that far out of line makes it articulate funny. Lower is to short to rotate the mounts down and the front hanger spacing would be off.
mjlogan
space cadet
Feb 9, 2007
683
49
ontario ca
I know the geometry isn't ideal, but I've followed Giant Geoff's DD Link Bronco around Baja for hundreds of miles and that thing kicks ass. Has body roll like a Spainish Galleon on the high seas, but it eats whoops, rides like a caddy, and is super reliable.
5,979
307
i wouldnt say that the links straight forward off the axle is a bad thing though. lots of trucks run it like that. i have a close friend who runs said link kit and he loves it. his truck has been rippin for a few years now with no issues. also, PERSONALLY i like more squat built into the link geometry.
