Diy beams
Dblankenship
May 4, 2020
Graham wa
Hey guys I have a 96 2wd ranger regular cab. Me and a buddy were thinking about building some beams for it with heim joints to connect the spindle. Then I can set the camber pretty easy. My only concern is i haven't seen this done yet. Has anyone on here done with style with success and not breaking. I know about using kings or cutting some tabs. Correct me if this isnt the right spot. Also the plans for the truck is mid to long travel. And leafs in the rear. Nothing crazy.
Jester9
The Jester's Workshop
Apr 1, 2014
412
150
Central Texas
It has been done but I do not know the outcome, the lower half utilized a uniball and the upper utilized a heim.
Jester9
Apr 1, 2014
412
150
Central Texas
Another consideration is that you will have to make custom hubs, more info on your build criteria would help... DD, race, fun trailer queen, budget, etc
Dblankenship
May 4, 2020
Graham wa
It's a dd at this time but I'm sure as it get farther along it will end up being more of a fun trailer queen. And I'm trying to keep it more budget oriented. And just out of curiosity why custom hubs? At this time I wanna try to keep it pretty small tire 31 to 33s. I live in wa so it will be mostly on the back country roads up on the mountains with some dunes trips to oregon here and there. New to prerunner mostly a background in wheels and some tube buggy stuff between me and my buddy.
6,381
867
youll need race hubs because youll be building custom spindles and theres no real good way to attach a stock hub to a custom fabricated spindle. the only non race hub worth your time will be a D44. no sense in worrying about the strength of the heims on the beam ends if youre gonna put stock hubs on them...those will go first.
heres another setup using heims and uniballs. personally, i wouldnt do two heims, just one with a uniball lower pivot
Reactions: ljubera0250
mikebrier12
220
36
California
If your trying to keep it budget friendly you might as well use d44 ends with ball joints and factory spindles. I believe setups above with heims only give you 5* of adjustment. if your building custom beams you can set them up to desired ride height and get about 3 degrees of camber adjustment with factory adjusters.
