Billet tcs C4 torque converter 2800 stall - sold
C4 to v6 ford pinto bell housing- sold
Econoline 9” setup with 4 link 5x5.5 bolt pattern 68” wms (about 80” wide with Alcoa’s and 35x12.5x15) 2 piston Ssbc brake calipers with wilwood rotors on moroso 5/8 studs with extra set of rotors. Needs new rotor hats (1 is cracked it still works just needs to be replaced)
Links are setup with lower bms pivots. - $500 - sold
9” 3rd member Yukon case, spool, motive 4.56 gears 1330 u joint yoke - sold
Buy axle and 3rd together $1000
