134
27
Tucson, AZ
So I'm pretty happy with how it is cycling only concern is at ride height there is 2.2 or so degrees of camber from true level. I tried moving the upper mount to fix it but that just screwed up other things. I don't care about tire cupping but is there any reason this would be a concern? I mean it is nothing compared to a beamed truck I guess.
2,278
2,086
everything is a compromise. shorten the upper arm some and see where that nets you. a little more camber change isnt the end of the world but you may run out of ball joint angle sooner.
2,278
2,086
you may just have to deal with the bump steer unless you want to re-do you spindle. you can always limit travel right where the bump steer starts turning bad as well. you aint going to miss an inch of wheel travel.
