Front of Toyota + kings valving
5lugger95
1,688
2
So I have a 1994 Toyota 4x with an older caddy kit that I need a baseline for. My motion ratio is 12/8 running a 600 lb/in spring. I'm using a 2.0 king C/O with 7/8 shafts and a remote resi.
What should I start off with on comp and rebound? Not going to be hauling ass down B main but I do want it to be well rounded
5lugger95
1,688
2
Try a .015 flutter stack with one bleed hole open for comp. 10's on rebound.
I was thinking of a flutter 15 on compression for sure, why not 12s on rebound? My thinking is the high 600 rate will need more rebound then usual. I also have very little experience with valving so my thinking could be off lol
orbot
Mr WTF.
Nov 8, 2007
2,132
5
Chula Vista
for the 1st gen taco, most guys recomend 12s for rebound
I dont think the weight changes that much
5lugger95
1,688
2
Yeah 15 flutter on comp and 12s on rebound I think is the move to start. What about bleed ports on 2.0 kings? One open?
orbot
Mr WTF.
Nov 8, 2007
2,132
5
Chula Vista
Well I re-valved my front SAW's this morning. I took them apart and found...
Comp = .12's
Reb = .15's
* 2 bleed screws in... just like Camburg told me.
So, I tried a flutter stack and I must have did it wrong because it was waaay too soft for the compression side.
I ended up doing what Jerry recommended...
Comp = .15's (stack of 5, took the old rebound stack out and put it on the comp. side)
Reb = .10's (stack of 5)
* 1 bleed screw in
The shocks had a .31 small dia. washer/ shim on the comp side under the shim stack, and then a rate plate. I used these just like they were originally only with a .15 stack rrather than the .12 stack.
After a little thrashing it seems to ride better, not on the airbumps nearly as much as before. I hav'nt hit any real whoop sections yet so I will still have to do some more thourough testing but Im in the ballpark now I think.
Thanks everyone for the advice, and thanks Jerry Zaiden at Camburg for his thourough knowledge of Toyota suspensions. :)
84prerunner
2:AM Fabrication
Feb 7, 2008
21,516
91
Covina CA
running a single 2.0? that thing is going to cook and be scary soft in anything bigger then speed bumps with a .015 flutter.
5lugger95
1,688
2
I'll throw a 2.0 smoothie next to it if the single doesn't work out
