Full floater rear brakes
Motiracer38
Super Senior Member
Feb 14, 2006
3,436
89
Santa Clarita
I am just about at a loss on what to do about the brakes on my rear end. It's an old protruck 4in housing Chrisman with Chrisman hubs. The axle and hubs were bought at separate swap meets so no guarantee the caliper mounts are correct for the brake hats. The twist is I still want to run 15" wheels which puts me into 12.25" rotors. I have some rotors with the correct 10 bolt pattern as the hats but can't find which caliper to run.
I have some wilwood superlites which have the 3.5" spacing mounting tabs but the 4" housing won't allow them to get close enough. It looks like most protrucks ran CNC calipers but the brackets on the axle are 5.125" spacing and as far as I've found CNC are 5".
Anyone have any insight into how to run brakes on 15" wheels on a 4" housing? Keep in mind I don't want to spend too much money and waiting till the next swap meet puts me past my desired completion trip.
Sent from my moto z3 using Tapatalk
Motiracer38
Super Senior Member
Feb 14, 2006
3,436
89
Santa Clarita
Funny thing is that is the only caliper I found with this 5.125 bolt spread but didn't want to believe it.
Move on to what budget oriented 15" wheel tuckable caliper?
Motiracer38
Super Senior Member
Feb 14, 2006
3,436
89
Santa Clarita
Thanks for the reality check Barge. I took another look at the approach I was taking and came up with an all around better plan forward. If I replace a dust cap on the inside face with a rotor adapter I can run a standard wilwood catalog rotor and it would fit mounts for the superlites I already have on the shelf. I have the adapter drawn up, now to find a shop to make two for a reasonable price
jonsangel
1,173
112
Los Angeles
That's essentially what I did on my front. I just waterjet the adapter blank then machined in the pocket for bolt head clearance
214981
214982
214983
My rear uses the superlites calipers and coleman top hats. That may be the easiest combo
214984
Motiracer38
Super Senior Member
Feb 14, 2006
3,436
89
Santa Clarita
Thanks, I'll look into those alternatives. The first two quotes back were surprising so I may need to consider a different method.
