Is this beam bent?
TEAM_LCQ
Apr 25, 2022
2
1
Sand Lake MI
Hi everyone, in the process of starting my first build on a 92 ranger. It has a set of extended beams on it. I'm tearing it down and starting fresh as the truck is pretty butchered up. Anyway when I was inspecting the front end I found my driver side beam seems to pushed back toward the cab about 1 3/4 in. Does this look right to any of you?
TEAM_LCQ
Apr 25, 2022
2
1
Sand Lake MI
Impossible to tell from the pics.
Where are you measuring from? Please tell me it’s at the hub…
[/QUOTE
Yes measuring everything to the center of the hub. Tonight I took a closer look at the beam and there is definitely a wave in the plating on the beam and some paint chipping. Going to try and press it back into shape.
11,308
2,777
Lucerne Valley, CA
That photo I see you are comparing the bump stop to bump pad and I am assuming it was all centered up before. Now if the beam is rolled BUT radius arm and caster at knuckle is same side to side then I would say that bump stop location caused the beam to bend. I always try and fit the bump stop outside the radius arms since inside like yours I have seen more beams bend from that than anything else.
