Just another I beamed ranger build
PeterN
Just another beamed ford
Sep 16, 2008
313
25
Huntington Beach
Figured it was time for an update only been 3 years lol. Destroyed this thing at New Years 2017 and decided it was time for a cage and a front end
Several years of no cage and off road abuse was causing the cab to fall apart, no other pics but I plated it all in and it’s still holding up
Tube layout of the cage
Cut the roof off to 360 weld and found a shitload of bondo and a welded seam on the passenger a and b pillar as if someone had only cut half the cab and then welded it back
Cab back on time for more bondo!
PeterN
Sep 16, 2008
313
25
Huntington Beach
Getting the 9” all set up with the 64 kit
Jack welding up the beam kit
Decided at the last minute to add ruffstuff ubolt eliminators to the rear end it specifically said not for use on spring under applications but I’m not a good listener.
Went with a tabzone truss again jack welding I’m a shit welder
Finished product the cleanest it will never be
Reactions: smokeysevin
PeterN
Sep 16, 2008
313
25
Huntington Beach
Beams getting finished up
Mounted under the truck
This cab is thrashed half way through this I realized starting with a fresh truck would have been a better idea but fuck. it here’s a before picture
All cleaned up
Engine cage time
Can’t forget the super sick dimple die shock mounts
Bumped and strapped at 18” with working heat and ac
PeterN
Sep 16, 2008
313
25
Huntington Beach
Mounting seats figured it was a good idea to slam a hole in my trans tunnel.
Seat brackets welded, stock dash was a nightmare to fit but I’m really happy with how it looks.
I finally have a real bumper! Lol
Swing steering install and final disassembly and paint
PeterN
Sep 16, 2008
313
25
Huntington Beach
After 6 months I finally got this thing driving and on its own weight
First trip was the memorial in Lucerne truck worked great only had a slight issue with the truss hitting a brake line
This first trip was the furthest I had driven the truck after caging it, we got it running, slammed bedsides on it and drove it 2 hrs to Lucerne smashed on it and drove home!!
Installed some sick oriley auto hids
PeterN
Sep 16, 2008
313
25
Huntington Beach
Full droop
Sand dunes in Lucerne
Nuked the transmission got use Logan’s AAA chase truck
Swapped in a 5speed which was a terrible idea lol couldn’t keep them together at all
Messed around with some 37s one day I’ll upgrade because gahh damn she looks good with 37s
Reactions: themoneypit
