king pin with dana 44
84prerunner
2:AM Fabrication
Feb 7, 2008
21,505
73
Covina CA
Looking for any info on putting dana 44 snouts and hubs on a 1" king pin beam. Looking for a budget friendly setup. would be cool to able to use stock calipers etc. ideas/info anyone?
9,248
257
Phoenix, AZ
machine seal surface on kingpin spindle to match ID of D44 spindle. Press D44 Spindle on then drill and tab knuckle or just weld that sucker on.
I've seen a 2.5 hub setup that was done this way. ID of snout was machined to press fit onto the seal surface of stock spindle. Then another piece was machined for end of the stock spindle to fit inside 2.5 snout. then everything was welded up.
5,986
309
theres quite a few fabricated spindles you can buy also. pretty costly though.
84prerunner
2:AM Fabrication
Feb 7, 2008
21,505
73
Covina CA
Trying to stay away from the machined snout block idea unless the same snout block would work with ProAm snouts as this is only a "temporary" solution. Welding the snout on it one option but not sure how the stock caliper would line up and redoing that for a willwood caliper is getting away from the point of this setup.
5,986
309
hopefully this doesnt side track the thread too much, but are you having issues with the f150 hubs?
9,248
257
Phoenix, AZ
Snout block for D44 and 12 bolt proam setup are same pattern 6x4" or 12x4" So a D44 just uses half the bolts.
5,986
309
ah i saw that. discouraging because thats what i was gonna run temporarily when i switch to kingpin
