Linked, Dana 44 TTB, 5spd 4.0l ranger - San Diego
crazyracer
Tres Cuatro Tacos
Sep 27, 2006
2,662
128
Pacific Beach, CA
I'm officially putting Snow White up for sale after 7 years with her. Looking to get some cash out of the truck and get serious about buying a house. In the mean time, I would be open to a partial trade for a 4 seater 4x4 - Been looking at LX470's.
The list:
4wd
Bronco TTBs with 4.56 open diff, MileMarker Manual Hubs: 4wd works great!
TTB's have had lower ball joint pushed out 1/2" with platting
Uniball ttb pivots
"CopyCat" D44 TTB mount brackets
2" .250 main radius arms
Steering
Single swing
.188 wall chromoly
Heim joints throughout
Pitman arm has full wrap with plating
Engine
4.0l, 205k miles. Runs strong. Recently replaced all the sensors
Water pump was done in 2014
Doesn't leak anything
Explorer dual-core aluminum radiator
Mechanical fan
2018 Full-River AGM Battery: Odyssey equiv
Run greats!
Fuel
Stock pump & sending unit, extended to fit in cell
RCI cell bladder - 30 gallon (has warped and shrunk to be closer to 22 gallons now)
Custom aluminum shell
Trans
2004 5sp, stock
New LUK flywheel 2018
New LUK clutch 2018
New Motorcraft (OEM) slave cylinder 2018
Custom Poly trans mount
Driveshaft converted to 1 piece
Axle
31 Spline factory shaft (Semi-float)
Stock 3rd member
4.56 gearing
Eaton Detroit locker
GM Calipers
11" Dodge 5x5.5 rotors
Plumbed with proportioning valve in cab
Could use a refresh throughout
Suspension
Single coilover on each corner
Rear air bumps
Well tuned
Strapped at 22" rear, 17" front
Giant Motorsports trailing arms (provisioned for bypass)
Cab
Fiberglass Dash
Stock guage cluster
12" Fi Audio Sub
1200w AMP
New door speakers 2018
New cab speakers 2016
Prp Suspension seats
Crow 3" harnesses
Vertex 2200 race radio
Odds and Ends
4 ammo cans mounted in the back for tools and parts storage
New headerpanel and lights 2018
Fiberglass hood
Comes with 3 spares (1 matches the Ar23 beadlocks)
I know every inch of this truck and have had countless successful trips with it. It's a solid machine.
Does not come with the hula girl.
PM me for inquiries.
$13.5K
