Little Bird
15,810
10,064
With a 4 link, one side is in tension which is strong. The other side is in comp and not nearly as strong. The longer your links the worse the column loading gets. With a 3 link you have the luxury of supporting that column mid span halving the buckling loads. Done right they ens up weighing about the same or less for a 3 link.
If 3 links were so bad, everybody would be using 2 radius rods instead of A-arms. Like a fucking Audie.
oorracing
Jan 15, 2006
10,673
237
Long Beach Ca
4 links are more common with the big trucks because of the way the heims see loads. On a 4 link they only see push pull loads whereas a 3 link sees loads from all directions, mainly side loads which we all know kills Heims. And depending on what you are trying to do, the pivot point being right over the diff can be unfavorable
Reactions: dose
littlebird
Feb 26, 2019
264
349
NY
If the 3 link has a horizontally oriented uniball on one end and the opposing rod ends on the 3 link have bolts/tabs that are oriented with zero degrees of lateral misalignment then there shouldnt be any side loading?
mikey09120
Michael Gonzalez
Dec 5, 2009
3,934
2,424
Camarillo, CA
www.facebook.com
Correct!
Just like the upper link on Ivan's truck!
It keeps the tubes on the line of action (less prone to buckling) instead of offset (more prone to buckling).
Reactions: littlebird
littlebird
Feb 26, 2019
264
349
NY
Got my heims, uniball, and bungs for the 3 link today. I ordered FK F2 fit 1-1/4 heims (FKBJMX16T) and they are STIFF. Like no chance moving with your hand stiff. Was this a mistake? Is F3 better for upper links?
All these little lessons while building a truck, they never stop!
