Odd 9" 3rd member question
sirhk100
Racer
Feb 24, 2003
16,232
146
Kind of in an odd place on a 3rd member. Basically lets pretend that maybe you had the bolts that hold the pinion carrier to the 3rd member housing back out and or shear off which allowed the pinion to slide out. The pinion pilot bearing got beat up in the process but other then that everything looks really good. Yes, we'll have it rebuilt before our next race... But, if I replace the pilot bearing and retaining clip.
Is there any reason I can't physically just slide the whole pinion back into place and install new bolts since I've already got the couple broken ones removed?
Yes, I know we should have it rebuilt, don't really care about your opinion... May just end up buying a whole new 3rd in the end... But for now just looking to buy a couple play runs with it before spending the cash to actually have it rebuilt.
Thanks
1,154
124
I don't know enough to say yes or no, but I do think of it like this:
If the band aid fix was to fail during a play run, what could be damaged? are you planning to replace all those potential parts soon anyway? what do you gain? what do you lose?
If I'm understanding correctly, I'm thinking you could lose the gears potentially, bearings, carrier, etc. all things that you would be replacing anyway, so run it. If you get a couple play runs, you win. If you don't, you don't really lose anything more than you already lost. Just my thoughts.
sirhk100
Racer
Feb 24, 2003
16,232
146
Yes, when it's rebuilt 100% of everything including possibly the case will be replaced anyways. If it dies playing we'll replace then. If it lasts playing we'll replace before lining up to actually race it.
The pinion slid out on it's own so I'm assuming I can get it back in as well. I pressed the new pilot bearing in last night and installed the retaining clip. I put about a minute or 2 worth of effort into getting the pinion to slide back in before I was interrupted and never got back to it last night. Seemed like it would go but couldn't get the last 3/8" or so to slide in and seat against the 3rd.
It's easy to say, replace it... When you're not the one spending the money. But when you look at it and there's literally no visible signs of damage from when it came apart other than the pilot bearing those of us that have to actually spend the money look at it and say screw it, let's spend $25 to replace the bearing and slap it back in to play with it more. When we line up to race next time it'll be new either way... We don't know when that'll be though...
1,154
124
im in your boat, id run it. worst case its a lesson learned to tell the next guy, who probably won't listen anyway... Slap her in and enjoy the truck all while getting parts together for the new 3rd.
5,984
309
[QUOTE="sirhk100, post: 3948734, member: 2735"
Thanks[/QUOTE]
why even ask. run it!
sirhk100
Racer
Feb 24, 2003
16,232
146
I underlined the actual question in the first post... Does anyone know if the pinion can simply be physically slid back in or does the ring gear have to come out, then install the pinion, then reinstall the ring? Cause if that's the case we'll likely have it rebuilt but if I can physically slide it back in then that's what I'm doing.
I'm not asking if I should or shouldn't run it, I'm asking if it's physically possible to simply slide it back in. I messed with it a little bit and didn't have any luck...
9,867
643
Slide that bitch back in! Bolt it down and check the backlash. Shim as needed.
The teeth on your ring gear may have some funny wear on them but at this point it doesn't really matter. Run it till it blows.
Can you drain the oil and check for chunk's?
Bertismyname
Oct 1, 2018
299
97
It's only money. Go for it. Probably going to be noisy. But if it happened during a race would you swap the third or put the pinion back in and run it? This is a good way to verify a "field repair" without the pressure of race conditions.
