Parting out my 03 double cab Tacoma
9,520
676
Phoenix, AZ
So had a bad rollover in the truck so I'm selling the good parts on it.
40 gal fuel safe fuel cell pro truck style new when I did backhalf
2.5x10 fox coilovers with 500/600 springs
3.0x10 fox triple bypasses remote resi shocks
2.5x14 fox coilovers with 400/600 springs
3.0x16 fox triple bypasses piggyback
2 2.0X3INCH air bumps
2 2.0x4inch air bumps
55inch trailing arms
Saw sway bar 55inch long with arms and bushings and links.
Econoline ford 9inch 35 spline currie shafts btf trussed 4 link mounts broken passenger side axle shaft missing 1 chevy brake caliper and bent caliper mount and broke softline
Strange 3rd 35 spline spool daytona billet support 6.0 gears. Trail-gear Toyota flange for driveline
6 method grid titanium 17 5x5.5 pattern drilled for 5/8 studs. 2 33inch pattle tires with them. 3 37x12.50r17 bfg km2 muds mounted. 4 un mounted Included as well has 1 shredded and 1 sidewall flat on truck.
2 Prp podium seats black gray tweed black vinyl back
Matching 2 pro high back seats
4 crow gray black hardware harnesses 2 5 points with pads. 2 4 points bolt inwith pads. All matching.
3.4l v6 135kish miles ran good before accident.
Jba headers and exhaust magnaflow muffler
Trd supercharger supra Injectors urd pulley urd FTC control box
03 tacoma prerunner 2wd auto trans with different valve body shifted very good chirped tires when on it.
Aluminum radiator with fan shroud 1.5In aluminum 90 welded on lower 1.5 straight on top
Drake small power steering cooler
Hanneman supercharger hood 4 pins one ripped out
Passenger front mcneil 6inch fender and broke driver fender but have all the pieces
2 broke badly but fixable with work 8in fiberwerx flat top bedsides
FULL CHASSIS WITH ABOVE PARTS REMOVED BENT FRONT LCA MOUNT DRIVER SIDE
Will sell everything for cheaper or ask for parts and I'll price them out. Will ship or can bring to thousand oaks area beginning of next month. Needs cab doors windows and fiberglass fixed
Front suspension needs driver lca straightened at inner mount. New spindle or straighten/strengthen it back up
Replace or straighten uca driver side
Passenger front suspension appears good. D44 HUBS WITH ⁵/8 WHEEL STUDS TACOMA CALIPERS HEIM STEERING
Reactions: SoupGFX
84prerunner
2:AM Fabrication
Feb 7, 2008
21,669
225
Covina CA
Sad to see, hopefully you are doing ok. Id love to see this thing put back together one of theses but it is looking unlikely at this point.
9,520
676
Phoenix, AZ
Fuel cell is wedge shape on top and bottom. Has 2 -8 pickups. 0-90ohm sending unit -6 return 1" vent 2.25" jaz filler neck. One 10inch coilover appears to have slightly bent shaft.
Reactions: SoupGFX
