Profender Air Bumps $139
ProfenderUSA
156
Profender bumpstops help you use all of your available suspension travel. Profender bumpstops feature a 1 ¼” shaft and a 1 13/16” high flow piston for superior bottoming control. We use a high pressure Schrader valve with a gasketed cap to keep out dirt and moisture. Profender bumpstops are fully rebuildable and tunable with simple hand tools.
We offer 3" travel with a open length of 13.42" and a closed length of 10.35". and a 4" travel with a open length of 15" and a closed length of 11". The maximum rated pressure is 400 psi.
Profender bumpstops are fully rebuildable and adjustable by adding or removing the internal shims and adjusting the nitrogen pressure.
Our mounting cans are the beefiest cans on the market. They are made from 3/16" steel and have 2 pinch bolts. They are sandblasted to ensure a smooth and even finish.
3" or 4" travel 2.0 bumpstops are $139 each, and the mounting cans are $26 each.
Check out our full line of products at www.profenderusa.com
ProfenderUSA
156
I talked to the factory, no red. Sorry
They are going to use red on the 2.5 bumps when they make them, no time frame given.
ProfenderUSA
156
Just so everyone knows, we are racing at Rausch creek this weekend. We are out of the office from Thursday afternoon until Monday. Hope we make it more than one lap this time. :)
