Project 2 Ghetto Build Thread
643
Bummer.. CHecked out my driver tire last night. It's blown to shit. 3x holes in it!!
I'm wondering if holes appeared as I pulled off trail? Seems strange. I will try to get pics. Either way.. there goes $250!
Top BJ adjuster is all wiggly too. I'm starting to wonder if the holes in beam are even concentric anymore.
Reactions: charlie_brown
831
268
need to put some discount warranties on those fuckers
charlie_brown
Aug 10, 2004
2,864
143
OC/BAJA
i used to carry extra BJ adjusters in my tool bags. had to change them several times. the problem i had was the ears were too close together and it would not set down enough. geoff (giant) cut them off and welded some builet ears on. no more problem.
643
How much that cost?
I feel like mine have been like that since day one. Could never get those damn adjusters in deep enough to really lock in. Both sides.
I am gonna try some fixed adjusters this time. I think I was at 0 before with adjustable ones. -.25 couldnt hurt.
346
71
If they are anything like the yota eccentrics the ears get bent or the holes get wallered(?) out and they knock around.
Total chaos makes a reinforcement kit for tacos but not Tundras.
9,429
492
Phoenix, AZ
I got a bunch of eccentrics off rock auto years ago for $7.50 or so each. Check rock auto.
Just checked email. Guess they were more than I thought.
charlie_brown
Aug 10, 2004
2,864
143
OC/BAJA
i forget how much he did it for. i sent them to dave 1st and told him what was wrong. he cut the lower bj the same way as doing a cut ad turn beam but just moved mine down a bit. but that was not enough. i dont think he has a tape measure.
so i bought some ends from geoff (pinch type) and he put my beams in his jig and made them good. no more problems. he told me the main reason they get bent is when someone replaces the bj, they tighten the upper more 1st and or with it off the ground. should be on its own weight and the bottom gets torq. then tighten the upper.
643
Well, I suppose it's good to know I can always get them cut apart and get converted to billet ends if needed.
I did it similar to what you said above..... I think maybe it was torque bottom to like 50, torque top to 100... then torque bottom again to 100??
I followed some procedure i found online that had a wealth of info about D44.
643
Dangit.. I was looking for 0/0 too.. that only had the 2x slots.
SPC 23109 looks to be EXACTLY that in your drawer
BUT>>> when I look online.. the picture shows the ones with multiple ears for that part number. Hmmmm (I was trying to avoid that because that's what breaks off my adjustable ones)
EDIT. well half look like the one above.. and half have all the ears. Based on what you show. that is what i should have got. Oh well. .25 more negative for better handling bro!
