Project 4Skinner: Unclean, Uncut, Unkosher and Unashamed
5,865
7,000
bottom mounted resi, why go 225psi?
1. Because that was what the regulator was set at and I was in a hurry
2. Vehicle was at ride height, so at droop pressure will drop a little
3. I usually run 200psi in bottom mount resi shocks. What do you guys run?
2,160
1,927
120, think fox or king call for 110 or some shit, i do 120 cause thats easy to see on my gauge lol. dont need a ton of pressure as you are not fighting cavitation.
1,764
Fox says 200. I have always done 200 as well. I doubt you need that much.
But they are correct about needing a decent amount of pressure for this part. I know that from experience when I try to assemble.
Charge!shock!with!200psi!of!Nitrogen.! Failing!to!do!so!now!will!allow!the!bearing! to!rotate!during!the!next!step!and!the!cap! will!not!get!tight.
Tighten!the!bearing!cap!with!a!face! spanner!wrench!and!lock!it!into!place!by! tightening!the!set!screw!with!a!5/32”!Allen! wrench.
Wow, hope this cut and paste looks like it does right now... No way I am fixing that! haha
ucd baja
#1 Pig Killer
Dec 16, 2008
2,088
1,147
Guinda, CA
Does it have an ARB air compressor? If not I run a Co2 tank w/ an ebay regulator in my CJ, I have had it 4-5 years and its only been refilled 2 x's. I use it for airing up my tires too. Its nice to not have to worry about wires and shit. Every time I'm on the Rubicon Jeep nerds are always having ARB locker issues and its the compressor. I bought my Pneumatic toggle switch and blow off valve from the powertank website.
225479
10,265
1,432
Yeah my Tacoma air locker i ran a T in the line with a Schrader valve and a ball valve for side to solenoid since my compressor failed and left me open doff 1 tire fire. Replumbed it with ball valve to close line with just Schrader valve to charge it with gas station air pump in needed or I had a bike high pressure hand pump id keep in my truck just incase.
