1,529
Dash looks awesome. You did a much better job at fitting than I did. I had it where i thought it was supposed to go then raised it like 2-3" after sitting in it and it hitting my knees. Raising it screwed up all my cuts.
I feel like this will be a knee knocker as is.... but i know it's not supposed to go any higher because then the top panel wouldn't match to the window sill. So, I am pretty sure I will need to cut out a pocket for some more leg room.
I think i need to mount seats first.. then complete steering. then evaluate.
I think that dash you got is a much harder install. this one is clearly a copy of factory one.
1,529
Got this.... but uhh.. didn't pay attention. iI doesn't have any tabs on it for mounting! Thinking of ways to mount it right now. Also trying to decide if flatter or angled.... looks like I had it upside down in pics. I will want wiring at bottom.
angled
more flat
and got the mini shelf more done on hatch... kinda like it.
Made the angles match the main chassis tubes again...
1,698
1,255
that is correct, top is IN and bottom is OUT. water pump pulls water, you wont want it to try to pull from the top where it can very easily suck any air bubbles in the system and cavitate.
Reactions: mikey09120
