Found one of my OG sketches from when i was planning cooler mount. Obviously I cheaped out and used store tabs. Funny to find this. Forgot I even did the sketch
And since I can't decide what to do on brakes... I went ahead and worked on some other things. That's the beauty of these big projects. If you can't make a decision... there are plenty of other things to do!!
Went ahead and got started on the seats. I noticed this tube wasn't in my notes. G4 turned out to be 45.5 mitered to 22.5* on each end... then 4" tube with 0* notch and 22.5* miter. When all said and done, tube was 45.25ish and 3-7/8. I used some 1.5 x .095 this time.
Have to have internal bulkheads...
And had to be recessed into the floor for max style points...
And found a good 110V setting for continuous welds on tube to the body (6-35). I only had a couple small issues.
All done.
Then I moved to dash. Super simple. I used the tabs from my cooler mount. Drilled them out to 5/16". Which reminds me... I need to go get more tabs for that...and some more 1.25" tube for seat mounts. Fucking tabs were like $3 each though! Oh well. Saves time.
oh yea, think I am gonna use the fancy fender washers too. But i will get black ones. Another rip off incoming...
Gonna add a couple more mounts down lower.... and not sure if I will want some up top. Gonna get some rubber bumpers from my brother to try up top first. (he works at Rubber The Right Way)
