1,764
i think we checked before and they are too big... plus they still aren't as "flush" or integrated looking.
Havent had any leaking issues on G3. As I'm sure you know ... the o-ring is between plastic and housing. as long as that plate is flat... and I dont warp it too bad. should be ok?
12,088
2,720
Absolutely hate using hole saws on plate. Thankfully I don't have to worry about it anymore with the plasma table, but otherwise I just use step bits up to 1.25". Kinda wanna get annular cutters though.
A.J.
OG
Jan 29, 2002
3,990
449
Yuma, Az
And again. Invest in a set of these, 2 sets available ranging from super small to 2”, definitely an investment that will open your eyes and make you cry thinking of all the screaming noise you listened to with a hole saw on a sheet of metal
Blair Equipment 11090N Rotabroach Cutter Kit
Reactions: ucd baja
773
422
Can you use them with a hand drill or are they drill press/mag drill only?
