2,682
607
Hey, I actually like the boomerang mounts! Truck stuff is always so angular. I dig the curvy lines.
Side note: is that wire by the upper shock mount (held on by electrical tape) used to keep reference of where the mount needs to be?
Thanks! I like the boomerang shock mount concept.
^^^exactly! That “wire” is 1/16” TIG rod wound around the AC dryer chingadera. It is a quick reference to approximate the upper shock eyelet location.
10,293
140
I know wire is predominantly used for electrical or bailing (spelling?) But I interchange filler rod and filler wire all the time hah. None of the filler i use is thick enough to be called a rod (that's what she said?)
2,682
607
WTK cut out the floor while I held the baby all day, and we prepared the seat mounts for metal glue.
BroBroBroBrent bandsawed some of the tie-in gussets for the seat tubes. The left-to-right seat tubes will be welded directly over the door tube, then we will add the pictured gussets and fore and aft gussets.
Unbranded seat: anybody know what it is?
2,682
607
Wasted almost the entire evening on Thursday making the boomerang shock mounts.
Here’s how it went down:
I made cardboard templates as outlined in previous post. Cycled suspension numerous times, measured, re-measured, re-checked with cardboard templates. Everything seemed copacetic.
Cut out 4X 3/16” plate shock mounts and tuned up the dross on the disk sander. I got them tacked in, installed the coilover, and the coils rubbed the upper a-arm at full bump. Sunuvabitch!
I’m still not sure how I pooched it up—I wasn’t even inebriated! (There’s yer problem!)
Went to bed on Thursday night cold, tired, frustrated, and defeated.
Saturday morning: Brent brought homemade breakfast and we attacked the shock mounts again. I was able to salvage and reuse 2X of the plates I cut out on the Thursday of infamy.
Clearance in the rear shock mount plate to facilitate master cylinder removal:
Passenger side:
Disassembled the IBPs—lots of cool stuff going on in there.
675
128
thats cool shit. i always figured they just used different needles for different ways of bottoming control. didnt realize they have 2 completely different stacks for when the needle is seated or not seated!
