Motiracer38
Super Senior Member
Feb 14, 2006
3,405
40
Santa Clarita
3m makes safety glasses with a foam gasket that snugs against you cheeks. Our work made us wear them and they were a horrible sweat fogged hazard but they work awesome when cutting or grinding. Even makes cutting wood outside in the wind tolerable. I don't grab a grinder or lay under a truck looking for pixie dust without them anymore.
https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-Virtua-CCS-Protective-Eyewear-11872-00000-20-with-Foam-Gasket-CLEAR-Anti-Fog-Lens-20-EA-Case/?N=5002385+3294733407&rt=rud
Reactions: Ryan Jubera
2,839
846
Thanks Brian. I procured some similar fog catchers recently:
2,839
846
(Temporary) Shock mounts coming together.
Drilled through both walls of the tube first with 13/64”, then opened up to 1/4”. Installed a 1/4” transfer punch as the holesaw pilot to reduce wandering.
Machined some slugs from 1.0x0.250” wall 4130 tube. Brent used the lathe to make one of those while I was in the house tending to the baby—Nicely done.
Nice rusty allthread to hold alignment during welding:
Not sure how I am going to double shear the mounts yet, but I have a couple options that will look reasonably clean and be easily removed when links happen.
oorracing
Jan 15, 2006
10,560
69
Long Beach Ca
Shoulda machined a step into the bung so the top caps eyelet slid onto it, thus eliminating one misalignment spacer and also removing the bolt from shear.
Looks good, i like the floating backhalf for future linked awesomeness lol
2,839
846
Thanks Kevin!
Machining a step into the bung would have been tidy! It only works for single shear, though.
I can always weld the inboard misalignment spacer to the bung with similar results if I decide to leave the shock mounts single shear.
With regards to the “Floating Backhalf”—the more I look at it, the more I love the idea! It is going to drastically reduce the work required to link the truck someday, whilst retaining usability during the parts collection phase. And it looks cool.
Did a quick cantilever beam calc, and the shock mount bung is good for 2300lbs+ without having to worry about material yield...
