jeepspeed
11,060
157
Phoenix Arizona
I still maintain that cutting a pie into the top of the rivet with a 4.5” grinder, then use an air hammer to shear off the pie pieces, then switch bits and air hammer out the rivet is by far the fastest and cleanest technique.
2 minutes each. Fucking done.
Agreed. Also if applicable, I just use an abrasive grinding wheel and grind the head completely flush. And then hit it with a punch/hammer.
1,767
488
Burn all the way through the middle then air hammer the thinned nub.
Hmmm maybe ill play with it if i have the time to see what's fastest. I can't really use the air hammer method with my sleeping son on the other side of the wall (which is usually the only time i get to work on the bronco lol.) But grinding is also probably too loud sooo that ends up being a wash. may bust out the air hammer after all.
518
192
You can go full thrust but its easy to slip and rip the edge of the hole. Then no one is happy
bajaf250
Mar 23, 2016
175
High Desert, Ca
Got a little carried away and drove faster than 17 mph. Giving a ride to Turboyota or chasing the brokota but miles of smiles is worth it.
Have a little sad power steering rack so its crying now. Time to replace it with vatozone warranty.
Got my AAA chase team coming now lol.
Sent from my SM-N970U using Tapatalk
Reactions: SoupGFX
