project side tracked / willys go kart
turbocourier 79
trying to build it all
Apr 5, 2005
1,711
256
southern oregon
ya it has been driving for a couple weeks
just a wire for the pull throttle still
hydro fluid gets hot with no cooler but i have 1 to put on and see hat happens
turbocourier 79
Apr 5, 2005
1,711
256
southern oregon
ya just smack it in forward or reverse and stab the gas
it is nice and slow. maybe 5mph
i think the power steering pump is pretty whack
i need a real hydro pump and the direct drive it
11,944
3,325
1-1 gear ratio on the pump? Most PS pumps are over driven , usually about 50% on a production car.
I'm still gonna say, twin pump that bitch!
turbocourier 79
Apr 5, 2005
1,711
256
southern oregon
i think it is slightly under driven
the motor still bogs out when trying to climb something so not sure what to think there
i think i might try and log splitter 2 speed pump next
pretty fun learning this stuff when it works out better each time
turbocourier 79
Apr 5, 2005
1,711
256
southern oregon
out with the old little guy
plasma on the firewall to get the crank poking through
little gorilla hiding in there!
machined out a flange to bolt on the log splitter pump
turbocourier 79
Apr 5, 2005
1,711
256
southern oregon
ya going to need a heat shield under there or something. cross that bridge when i get there i guess
there is about no extra room under the hood
the spark plug boot is about 1/4" too tall for the hood to close. this is even after i trimmed it down. i need a 90 degree style
turbocourier 79
Apr 5, 2005
1,711
256
southern oregon
sooo i got the whole new mess together pretty painlessly
for some dam reason there is something slipping/bypassing pressure
for log splitting powerful shit it does not really have any kind hydro-static feel
it slips easy when driving on flat ground at half throttle or more
i can stop it while driving with the brakes and full throttle it no trouble. zero speed all revs
i cranked the spool valve all the way down and that made no change
i imagine the pump has no internal bypass?
https://www.ebay.com/itm/11-GPM-Hydraulic-Log-Splitter-Pump-2-Stage-Hi-Lo-Gear-Pump-Logsplitter-NEW/271715961076?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
this is the valve
https://www.ebay.com/itm/PRINCE-HYDRAULIC-CONTROL-VALVE-2500-SERIES-SINGLE-SPOOL-PART-RD2575T4ESA1/251891216220?epid=1500263411&hash=item3aa5e2ef5c:g:3oMAAOSwrklVAaNh&_sacat=0&_nkw=RD-2575-T4-ESA1&_from=R40&rt=nc&_trksid=m570.l1313
i can see the resivior flowing lots of fluid when power braking it at no speed. so i think the pump is there but why no balls on the valve???????
