koolaidmanguy
Jan 19, 2010
296
77
Woodland Hills, Ca
Probably a noob question, but where the lowers connect to the frame, what's the idea behind moving the front lower pivot location to the rear? is it to make room for bigger steering components? for strength? or does it just eliminate the need for a subframe? ive seen it done on quite a few toyota 2wd trucks but never understood why. Cant wait to see the final result. lookin stylish so far.
2,682
607
It facilitates clearance for the idler and pitman arm at full bump. A “subframe” of sorts is still required, it’s just moved to the rear.
I have seen quite a few forward mounted, tension-style lower arms break at the 3/4” heim location or tear out the tabs on the strut frame.
Thanks for the compliment! One of these months I will finish the arms...
