2,733
685
New steering scheme to clear the girthy 3.75” ID coils.
2 beers thus far....
2 Fucks yelled, including a “Fuck Yeah, Bitch!!!” When everything cleared on take 1.
And it’s looking like 17-18” travel; still have about 1/8” bumpsteer that I may or may not try to eliminate...
Reactions: dalandser
9,841
613
Mitered tube upper arms are so 1997.
212396
Note the notch to clear the steering shaft. Moved the upper mounts in to lower the camber change. This made a few clearance issues.
2,733
685
Nice! I like seeing pics of your old truck.
The clearance issues are no joke on little Toyotas. Packaging is a challenge fer shur.
I have around 1/8” clearance on damn near everything on this truck:
wastegate actuator to cage—1/8”
Steering box u-joint to a-arm tabs—0.090”
Coil to steering shaft—3/16”
Steering shaft to turbo—3/16”
Tierod to pitman arm—still looks like it might hit... dangit...
Rear of lower arm to frame—1/8”
Tire to fender—2” interference
2,733
685
Time: 8 hours
Beers: 7 or 8? Coors light, Franziskaner weissbier
Lunch: German food
Music: Maiden, Offspring, Sepultura, Metallica, Slayer, Pantera
Times that I stuck the filler rod DIRECTLY onto the tungsten: 3
Blistered burns on my fingers: 3
Steering column install/removal count: 4
Done with the difficult side:
Finished the top frame plating on the easier side:
themoneypit
Jul 30, 2018
Missouri
I guess the anti-dive is more of a nuisance than anything in the dirt. Plus the wonky caster changes it leads to. On a ranger at least, it leads to negative caster at full droop. I'm guessing the Toyotas probably aren't too different.
