3,008
1,127
Front suspension is nearly complete:
Shocks: King 3.0x10” IBP with compression adjuster. Unknown valving.
Bumpstops: King 2.0x2” 72cc oil, 75psi
Spring rates: 10” 400 over 10” 500(May flip them for shits ‘n giggles later)
Secondary slider stoppers: set 2” above coil separator at ride height.
Track width: 82” at ride height
Travel: 17” bumped and strapped, braaaaah
Brake pads: EBC Yellowstuff
Calipers: Wilwood 120-11131 1.62” piston, 4.12 sqin piston area
Rotors: Wilwood 160-5844 12.19” dia, 0.81” width
Hubs: Speedway Engineering 5315-11 (fuckin’ 7075 aluminum, bitches!)
Snouts: Coleman 2” 811-102
Axle nuts: Coleman AN-853 (45 ft-lbs)
Reservoirs mounted SPECIFICALLY to trigger the OCD crowd:
1,349
212
triggered... But only cause you won't give up those 10" 500#'s lol.
Looking good dude, can't wait to see er' rip! Are you going to take a peek at the valving or just run it first?
