4,254
683
It boils water out of the reservoir.
I bought the tester kit to see if there are hydrocarbons in the coolant. I want to make sure there isn’t a big problem(cracked head/fuckered head gasket).
I believe you saw in the daily but thought I would say it again. My 22ret tested fine at idle. Once it got some boost it had a blown headgasket (Actually head was cracked). Nothing leaked at idle causing all tests to pass. Once driving it boosted and blew the exhaust into the coolant boiling it.
4,093
2,974
Did you use the chemical test for hydrocarbons?
