Radiator mounting pictures
3,849
2,543
Not a baller radiator, but mounting methodology could be similar.
Mine is a Northern radiator with lips on the top. The hold-down clamp has 3/4” thick rubber that contacts the radiator. Bottom is on McMaster-Carr vibration isolators.
Drayke
Always Baja Bound
Jan 29, 2007
1,035
270
Torrance
Here's how my top clamp looks. I was dealing with hood clearance problems otherwise I would have just used a bolt + nut vertically welded to the piece that pushes down on the radiator.
Bottom mounts are just simple cups off the frame rails that match the profile of my side tanks.
1/4" rubber sheeting between the steel & aluminum surfaces.
Reactions: ucd baja
