Ranger ttb 44 swap questions
Mrtacotrd
Nov 2, 2021
2
1
Maryland
92 ranger 4x4 ttb 44 question. I have read a ton about the swap. If you bolt the ttb in stock ranger location you need to shorten the passenger inner axle shaft about 2 inches. Why doesn’t the drivers side need be be trimmed? If you use the stock ranger pivot points do the wheels stick out the same distance on both sides? I wanted to just use the swap brackets, but man they are not exactly cheap.
Jr.fab
1,693
126
Hell Cajon
Sent from my SM-G935T using Tapatalk
Reactions: Rowdy Fitz
Mrtacotrd
Nov 2, 2021
2
1
Maryland
Thank you!
Reactions: Jr.fab
