Started tearing out the spaghetti mess of wiring on the drivers side. Truck had some aftermarket stupid anti theft module. Some neck beard definitely installed it, T taps and wire nuts. Yanked all that shit out and cleaned up the factory harness some.
Speedo still doesn’t work. Verified the speed sensor it working, wiring is good, odometer works, just no speedo. Everything points to a bad speedo. The brain for all the gauges is in odometer, pulled it out of the cluster, nothing obviously wrong. I ebayed a new cluster for $100, hopefully that works.
Started on the valve cover gaskets since they are leaking really bad, so bad it smokes when the oil drips on the exhaust. Came apart fast, nothing exciting under the valve covers.
[mention]Blood Eagle [/mention] [mention]Turboyota [/mention] [mention]dose [/mention] or any other Toyota bros, what’s a good timing belt kit for the 3.4. I’m going to do the timing belt/water pump while I have the motor apart. Took a peak at the timing belt and it looks pretty old/weathered.
