Simple mid travel buggy build
desertbound1024
593
1
you may want to consider doing a half sleeve on the inside of the tube, that looks like a big chunk removed.
I'm going to be plating, and running a support tube to add strength where I notched the frame. Will get pictures as I go.
15,850
10,146
They look like they need to go a little farther. On car with short trailing arms, the top of the shock usually ends up being about where your head is when the angles are right LOL.......
Remember, your not measuring of the top of the arm, but the line from the arm pivot to the bottom shock pivot.
desertbound1024
593
1
With how limited head room is, I can't go any farther hahah. Hopefully it will be fine where it is.
desertbound1024
593
1
Anyone have a ballpark number on what my spring rates should be close to in the rear? Right now it's at 275/450 and seems like too heavy of a spring. Can't get any more sag out of it, and it only has a few inches of down travel.
desertbound1024
593
1
I have the opportunity to trade the 2180 that is currently in my car, for a Honda 3.5 with everything to adapt to a VW platform. The 3.5 currently has an MSD Ignition and carburetor setup. Is it worth trading or would the 3.5 not be well suited for my rail?
